How Does The 4wd Work On The Gmt900s?
I never feel when the truck engages 4 hi and only hear an audible cluck when going into 4 lo. In my brother's 01 Yukon, you can feel when it shifts into 4 hi. Does the GMT900 use a CV joint or something to attach the 4wd?
Anyone have the schematics of the 4wd system?
I don't know why, but stuff like this makes me curious. :lol:
in mine, you know when it's in 4lo and it doesn't go easily..... from what I've read, there are clutches that engage the front end.
You should hear the clunk in 4HI, but to get your truck into 4LO you need to:
1. Have your truck rolling (under 5 mph)
2. Place the shifter in N
3. Move your switch to 4LO
It will not engage unless your truck is moving, you should see it blinking if your not moving. Or at least that's how my truck works.
I know how to operate the 4wd ;)
I'm curious as to how it actually functions. Is it more like a true AWD system in which it uses clutches for the front end or does it still use strictly gears in the transfer case?
Most likely it has an actuator(electronic) as the past two platforms have had. Although I have not heard of any going out on anything later than a '99 classic silverado. I am fairly sure this is the way the 4WD works though.
Question on engaging 4wd. I was taught that you stop the truck, put it into 4wd (no need for Neutral for high, only low), move backwards in reverse briefly to set it in, and then take off. I have never had problems doing it this way. Is it better to be slowly rolling (except for low of course) to engage it? And what have you heard about rolling backwards? Any need for it?
I shift into neutral, stopped or not, and then re-engage Drive(or limit the gear by chosing) and go. however there are many times when i simply do not have enough time to do these steps and i press 4 HI and put it to the floor. i have engaged at 20 mph. hope that helps.
In my 99 Sierra (Autotrac) there is no real indication of the change to 4 hi at any speed and I've gone into 4auto at 50+. I always completely stop to engage 4lo, in neutral. The only time it didn't lock in within 2-3 seconds was when a rat chewed the wires to solenoids.
this is not necessary on any GM trucks as far as I know, GM has "shift on the fly 4wd" - I know on the early 90's Fords you had to stop, put it in neutral and all that jazz, and to unlock their auto hubs you had to back it up sometimes. You can engage 4Hi and back to 2wd at any speed at any time, auto trac or manual shift, doesn't matter. The only exception is to not do it while the drivetrain is under load (during excessive throttle), in that case the auto transfer case will wait until you let out and the manual transfer case may grind gears.
the truck does not have to be moving to go in 4lo but it goes in faster if you are
I hope not, if I were stuck and wanting 4Lo, this would make me very unhappy.
Question: Where are the front CV axles physically locked? Does that happen at the hub, or in the front diff? I'm assuming it locks in the differential and that there is a slip clutch in the transfer case, but this is my first GM 4wd, and I haven't worked on (or studied) the system at all.
it's locked in the front differential. the hubs are never disconnected. The front diff is a open diff and uses an actuator to engage it. the transfer case is gear/ chain driven - the only GM transfer case to use clutches is the AWD systems.
The Autotrac transfer cases have a clutch to engage the front drive shaft. When in auto the front actuator is engaged and upon wheel slippage the transfer case module engages the clutch until slippage stops. In 4hi & 4lo the front axle is engaged and so are the x-fer clutches.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 679 Guests (See full list)
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
